8.8 with LS1 brakes
8.8 with LS1 brakes
Has anyone used the LS1 rear brakes on an 8.8 ??? I would like to use the long axle on both sides. Using the two long axles would narrow the rear end 3". That said it has the Ford Explorer tube ends. I am not sure what to do about my brakes. Thanks, David
My 8.8 is out of a 2000 Exploder. It is a 31 spline set up. I was trying to lengthen the passenger side to the same as the driver side. Now I find out my LS1 brakes will not fit. So should I just cut the ends and replace them ones that will accept 31 spline bearings and LS1 backing plates ??
Thanks again for your time.
Restricted User
I used a mustang 8.8.
replaced the axles with 31 spline Moser axles and used a welded explorer diff. Redrilled the rotors/axles for the 5 x 4.75 bolt pattern and used the mustang rotors/calipers. Cost me the $200 for the 8.8, $270 for axles and 25 for brackets. Was in it about $500.
