quick performance 9in help
Just put together my 9in using factory 10 bolt backing plates that I cut and the diff is very hard to turn over. Its almost as if the bearings are pressed on alittle to much. Anybody ever had this happen?
Mine went in fine except 1/8 or so and then once I bolted the backing plates on they went all the way in. I just wonder if the quick 9 housing is a little to short.
