narrowed rearend help
Rear is narrowerd 3ins on each side im having brake fitment issuses now. The bottom of the caliper is hitting the housing. Guys with narrowerd rearends have you ran into this?
Lt1 rear brakes, quick performance 9in housing, The caliper where the bolt runs through for the emergency brake is hitting the bracket on the housing.
LT brakes and narrowed housings do not work well together because of the size of the caliper. You have a couple choices, purchase Strange brakes and press off your factory backing plates to use theirs or swap to LS brakes but then your brake gap will be off.
