My 8.8 build Update 2/18 it's in
Old 10-21-2015, 04:47 PM
  #41
All Pontiac WS6's Avatar
Default 8.8
Looks good....
Time to put it all together !!!!!
Old 10-21-2015, 05:15 PM
  #42
hiltsy855's Avatar
Sweet!!!!!!!!!!!
Old 10-23-2015, 09:47 AM
  #43
95sscamaro's Avatar
The next group of parts came in this morning, I'm opting to have everything new in the rear. The gears should be here tomorrow, and the axles are the middle of next week.
I still have to call DSS or PST for a driveshaft, has anyone do the strange 1350 flange know the specs for it, going to a t-56? Wouldn't one for a 12 bolt fit?
Old 10-23-2015, 10:46 AM
  #44
JRENIGAR's Avatar
Don't understand what you are asking? It looks like the strange 1350 yoke you already have. BTW you are gonna need a 3rd quart to get it filled up.
Old 10-23-2015, 04:21 PM
  #45
95sscamaro's Avatar
How long should the driveshaft be, would there be any different when using this flange?
Old 10-29-2015, 05:07 PM
  #46
95sscamaro's Avatar
The axles came in to day, they look to be great quality and the customer service was excellent!! I now have all the parts to put this bad boy together, just need to find the time to get on it.
Old 10-29-2015, 07:50 PM
  #47
hiltsy855's Avatar
The axles look great. Those are 31-spline axles to fit the 10-bolt tubes, right?
Old 10-29-2015, 08:27 PM
  #48
95sscamaro's Avatar
Yes and 3in shorter per side
Old 11-19-2015, 12:43 PM
  #49
Rise of the Phoenix's Avatar
Any updates?
Old 11-20-2015, 02:04 PM
  #50
95sscamaro's Avatar
Unfortunately not yet, i have been so busy with the job change and with the end of the school semester, plus i'm going out of the country for the next week. But plans are to start next on it the first week in December. I need to get a new fuel pump and order C Clip eliminators for the rear.
Old 11-20-2015, 02:06 PM
  #51
95sscamaro's Avatar
Originally Posted by Rise of the Phoenix
Any updates?
How do you like those coilovers?
Old 11-30-2015, 12:36 PM
  #52
I like them a lot. I think I've finally got the compression and rebound adjusted to my liking and driving style. The cool thing about these coilovers is you have the ability to adjust ride height, as well as get the car setup for street driving, street racing, autocross, track events, etc. Install was pretty easy as well.
Old 12-04-2015, 04:49 PM
  #53
Spectre86's Avatar
get it swapped in?
Old 12-07-2015, 10:59 AM
  #54
95sscamaro's Avatar
Im not going to be able to get it in before Christmas, but i did go get the car and bring it to the shop.
Old 12-14-2015, 02:59 PM
  #55
Mean87SS's Avatar
Which axles are you guys using with these?
Old 12-15-2015, 01:11 PM
  #56
95sscamaro's Avatar
call Dutchman axles and tell them your doing a 8.8 with 10 bolt tubes, they'll get you the right ones.
Old 12-23-2015, 08:44 PM
  #57
95sscamaro's Avatar
A little update
I got the car running again it needed a new fuel pump and injector clips. I ordered up a set of front tires for the car and got those put on today. I must say for never driving a car with skinnies before it's really not all bad, the steering has a lighter feel and you Know there are up there but it's totally manageable. Also to my amazement the ABS light did not come on Being that I have 26in/28in tire combo.
Attached Thumbnails My 8.8 build Update 2/18 it's in-image.jpeg
Old 12-24-2015, 10:08 PM
  #58
Vicious95Z28's Avatar
Wow, this is starting to get more and more tempting! What would a guy need to do to keep his 1LE driveshaft?
Also curious if anyone has used a spool or had c clip eliminates installed?
Old 12-24-2015, 10:31 PM
  #59
95sscamaro's Avatar
I'm pretty sure all you would need to keep your DS is just the conversion u joint, and the rear flange of the ford DS. Wouldn't see a problem using a spool, and from what I could find no one makes a direct bolt in c clip eliminator setup for the fbody 10 bolts.
Old 12-25-2015, 05:12 AM
  #60
Hmm, the only problem is a spool doesn't use c clips..atleast the Strange unit I was looking at didn't appear to.
Quick Reply: My 8.8 build Update 2/18 it's in
