...and there goes my 7.5 rear
Old 10-29-2015, 11:01 AM
6spdg37s's Avatar
my tire was super sticky already mt et 255/50/16
Old 11-02-2015, 05:27 PM
6spdg37s's Avatar
the cam im gonna run they told me to run a 4.86 gear with ? anyone running that gearing with a 6mt ?
Old 11-12-2015, 07:25 PM
790ONMUSCLESREDTA's Avatar
How do I know If I have 7.5 or 8.5 where is It on the rear
Old 11-13-2015, 05:03 PM
6spdg37s's Avatar
all the third and fourth gen f-bodies had 7.5 inch 10 bolt rears... its the same rear that was used in a 4cyl s10.
Old 11-22-2015, 08:10 AM
6spdg37s's Avatar
ok I decided that based on the cam setup I am going to go with that I am going to run a moser 9" 4.30 gears 35 spline spool with the LCA relocation brackets and 4 channel abs/tc
Old 11-25-2015, 05:41 PM
6spdg37s's Avatar
So I ordered my rear through spohn. Moser 9" with 35 spline spool , 4 channel ABS/TC , fill/drain bungs, lca relocation brackets, 4.30 gears, 1/2-20 x 3" studs, stock rear brakes going back on. also got rear LCAs all their stuff is on sale for black friday-cyber monday..i saved couple hundred bucks
Old 12-05-2015, 09:24 AM
6spdg37s's Avatar
what gear oil should I run in this with the spool setup also I assume that I do not need friction modifier!?
Old 12-06-2015, 12:20 AM
Burken01's Avatar
Run some standard 80/90 non synthetic for break in
No need for the friction modifier with a spool
Old 12-07-2015, 08:35 PM
6spdg37s's Avatar
got it !
So 2 of the 3 boxes got delivered today, next one is coming weds.
Hopefully doing this sunday at my buddys shop where I used to work.
only issue is I need to get it done in a day (or at least rollable) because they need the lift for work monday.
Old 12-10-2015, 06:02 PM
6spdg37s's Avatar
I am actually gonna do this outside of the shop on jack stands because I cant risk tying up a lift. already dropped a 500 WHP SC mustang rear out on the ground the other day
Quick Reply: ...and there goes my 7.5 rear
