8.8 and 4 link questions
Trying to get all I will need to install an 8.8 rear and a 4 link suspension.
What will I need. I've seen some 4 link kits on eBay. Will i need coil overs?
Anything else. I know I will have to weld the mini 4 link onto the 8.8. So I won't need a torque arm because I will have a 4 link correct??
Any and all positive comments will be appreciated.
Thanks.....
Thanks.....
Post a link of the kit you are looking at (if its allowed) No torque arm, the 4 link will locate your axle front to back (plus pinion angle, etc) and the panhard will locate it side to side if what I am seeing in the kits is correct.
If you are looking at doing what they call a mini four link that attaches the "upper" control arms to the lower control arms I'd advise against it. Those that have tried it didn't like the outcome and this is why you don't see it discussed today.
If you research instant center it will explain why it doesn't work.
Link to eBay kit
Here is the kit I'm looking at.
http://www.ebay.com/itm/Weld-On-Tria...JTUBe5&vxp=mtr
I know what I need is triangulated and not parallel.
What do y'all think go this kit?
From the look of that kit it will make things worse.
Too much or too little IC can cause a loss in traction, sometimes a great deal. It will plant the tires too firmly causing the sidewall to distort, or not firmly enough causing them to just spin. There are so many factors that can alter your desired IC that it is next to impossible to weld on a universal kit and improve your traction/handling.
Now if you get a 4 link calculator, and go through the time consuming process like I did, you can get a suspension that works better with your car, style, and power.
Long story short, there is a reason the vehicle specific, proven kits are far more money...they took the time to figure what would work.
Hiltsy thanks
. Looks good. I wanted the triangulated so I wouldn't need to run the bar to center the rear end. But I can just add that to this kit. M
Wonton
Benefits are not blowing up my 7.5 rear. I have over 500hp. And the 4 link helps you hook on launch.
Wonton
Ok sure, still doesn't answer my ? about the 4-link vs a TA setup though, especially on a car designed to have a TA.
I mean this dude seems to do alright with a TA: Pretty fast 6-speed f-body
EDIT: Don't you also have to give up your PHB for this?
My vote would be to stick with a TA setup, and look into a used 9" or 12-bolt. I'll be quiet now.
The following users liked this post:
vettster (09-01-2022)
Yes people have done it but it isn't very common especially for drag racing. It is hard to out do a four link suspension.
I'm not sure I'd say that. I personally don't know any Mustang that has moved to a torque arm for drag racing or road racing. Now I've seen Mustang chassis converted to a ladder bar and some do confuse that for a torque arm.
And there are at least 3 companies (I won't link since they aren't sponsors) that make the kits. I'd say that's pretty common.
