Rear gear oil
Rear gear oil
New gear set says to use 80w90. I'd like to follow the instructions. But 80w90 is not a very common oil at my stores. They have Mobil 1 in 75w90. Will that work the same. It's synthetic btw
LS1Tech Administrator
Received 1,489 Likes
This is an important consideration. For example, the stock '98 rear calls for conventional oil due to the Auburn LSD. Changing gears won't change this requirement. If you have a Torsen LSD, then synthetic is fine.
