Is it possible to buy a new rear for $2500?
Base package shipped with a torque arm and crossmember is $2999. If you spent $2500 on a moser stamped nine inch or even purchase a S60 then added in the cost for a torque arm and crossmember at $400 plus you just spent the same amount of money or more.
Minus the fact at the $2500 you are getting a differential that is prone for having issues. The person trying to sell it to you even states he has had a few problems with them.
LS1Tech Sponsor
Have you ever had a brand of differential that hasn't broken for someone, somewhere? I haven't, and I highly doubt you haven't either. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Lucky Americans getting things for the actual price not practically paying double by the time you factor in shipping like poor Canadians.
If you're able to get a fabricated rear for around $3k with the torque arm I'd say go for it. You're going to have to spend that 500 dollars on a torque arm regardless if you're currently using the stocker.
I priced out a rear from every one of these vendors and just couldn't stomach the final price. *with the way the Canadian dollar is* so I opted for a seasoned rear (which I traveled 21 hours one way to get) I was also looking into the base packages with spool, because why would I want to put a differential that can potentially break or wear out in something I don't ever want to touch again? And If anyone tries to spoon feed you the idea that a spool is unbearable to drive on the street they're up their ***. *though you won't be doing a full turn around on a one lane street in one sweep*
disregard the above statement if your car isn't drag racing orientated of course. Keep in mind everyone has a different tolerance level.
OP I wish you the best of luck on finding a rear that suits your needs.
This is why we offer multiple differentials, we are not limited to what Moser or Strange offer.
Ok I'm looking to possibly order today. I think a tru trac, 35 spline, 9 inch would be perfect. I think with the $100 off I could get that for under $3000 shipped? Is there an email I could contact you on? Id like to make sure this will hold 600-700 hp, and I have a few other questions on what I would need as bare minimums.
LS1Tech Sponsor
Thanks! Bob
__________________
Super Hulk Smash
So, I see the 35-spline and 31-spline options for the TruTrac with the 9"... which would be better with 600rwhp with an automatic? Just go with the 35-spline?
Also, given that I have a 3.5" driveshaft already, I believe it was 1" shorter than factory with a longer yolk, would that work in the 9"? I know it was bought with the idea of going with a 12-bolt. But it looks like the 9" needs a shorter driveshaft? And S60 considerably shorter?
LS1Tech Sponsor
The 9 inch requires a one inch longer driveshaft than the 10 bolt and 12 bolt use. Bob
__________________
If someone is interested in saving money and don't need the housing assembled we could build a Moser stamped housing package together building the center section in house.
LS1Tech Sponsor
__________________
#32
I do to as well. Considering we offer Moser and Strange there is a trade off between the two. A nine inch will give you easy gear changes but because they shift the torque arm bracket to the drivers side and the pinion to the passenger side it makes contact with the floor leaving a nasty dent plus it may put the driveshaft close to some manufactures driveshaft safety loop. You also have to pay for a drain plug.
A S60 is not as easy to service as a nine inch and is limited on gear ratios. It is also one of the heaviest rear ends on the market. It does however come with a drain plug plus fluid. Couple downfalls are some rear aftermarket covers hit the PHB and if your vehicle is slammed to the ground the torque arm bracket too can make contact with the floor.
Downfall on both is any cast style housing will have limitations based off of HP and weight, this is why you see builds progress they eventually go to a fabricated housing.
Still your best bang for the buck will always be our fabricated nine inch. If you consider the cost of our package that includes a torque arm & crossmember compared to purchasing else where you will see that we end up being the same cost if not cheaper once you factor in purchasing a torque arm and crossmember that doesn't come with any other rear end besides an M9 that is priced well above our fabricated housing.
Some downfalls to us has been the wait at times but now in our new facility we have more room to get items manufactured and out the door. Wait time on builds are minimal dependent on the options you choose. Custom colors will add to the time frame over our standard black but we can have other colors done. We have had Red, Yellow, Green, Blue, and Purple. It has always been a very popular choice to mix red and black items together for rear end packages.
We also allow customers to put down a deposit and pay as they can with no limits on how much you pay at any given time or how long it takes you to pay off your order. This has helped customers build the rear end they always wanted and if your current rear end is not broken it allows you to still use your vehicle and pay for your rear end. Once you pay it off swap the two and sell your stock rear end why it still has value.
Any questions please feel free to ask.
#33
LS1Tech Sponsor
The OP bought a Moser 9 inch with a Wavetrac from me. Thanks for the order. Bob
__________________
#35
LS1Tech Sponsor
The standard nine inch would work out well for your combination. Bob
__________________
