Strange S60 experts? ABS questions
So I am looking at buying a wrecked 99 fbody that has a strange S60 in it. The only problem is my car has a 3 channel ABS system with no traction control and the strange has a 4 channel rearend. I was looking at strange's website and it appears the strange rearend has a provision in the center for a 3 channel abs sensor like the one I have. My question is what I need to do to change it over to the 3 channel system? I'm pretty sure I would need to install an abs tone ring onto the spool in the rearend but wanted to see if that's all I need to do and if it can be done? Not sure if strange sells these tone rings or where I would get it? Any advice or should I just buy a 3 channel rearend off jump street? It's worth mentioning I am getting a smoking deal on the rearend and it's only a year old. Thanks
You would need the tone ring, and the hole to mount your center sensor and thats it. Do they even make one that works on a bigger diameter center?? I have no ******* clue.
