Measurements??
Measurements??
i am wanting to install a 31 spline full spool into an 8.8 4 lug rear. I know that I need the c clip eliminators.
Question is this. Will a 31 spline axle still use the same axle bearing behind the brakes as the 28 spline? I dont want to spend money on 31 spline stuff only to find that I will need bigger tubes themselves because the axle bearing is larger. Also, is the differential bearing a different size as well for 31 vs 28 spline.
I have disassembled the axle down to what needs to be cut off for the c clip eliminators. But most eliminator kits don't specify 28 or 31 spline axles.
Below is the kit I am looking at getting.
https://www.ebay.com/itm/331396939902
