Differential Problem Diagnosis
Not sure if this has been posted. If so here it is again. A great little WTF is going on with my rear end.
Diagnosing Ring and Pinion Gear, Differential, Axle and Driveline Noise
Whirring noise only while decelerating at any or all speeds is most likely caused by bad pinion bearings or loose pinion bearing preload. This kind of noise is almost never caused by bad ring and pinion gears.
A howl or whine during acceleration over a small or large speed range is usually caused by worn or burned ring and pinion gears or improper gear set up.
Rumbling or whirring at speeds over about 20 mph can be caused by worn carrier bearings. The noise may change while turning.
Regular clunking every few feet may indicate broken ring or pinion gears.
Banging or clunking only on corners can be caused by broken spider gears, lack of sufficient positraction lubrication or antifriction additive, or worn positraction clutches.
Rumble while turning may indicate bad wheel bearings.
A steady vibration that increases with the vehicle’s speed can be caused by worn u-joints or an out of balance driveshaft.
Clunking only when starting to move or getting on and off the gas might be loose yokes, bad u-joints or worn transfer case or transmission parts
