12 bolt moser question
I have a 12 bolt moser in my 99 camaro with 33 spline axels. I have a strange noise coming from the rearend when driving straight at low speeds and when turning. Was wondering if anyone might know what it could be and what parts I would need.
Could be a lot of different things. Check the easy stuff first, hopefully it's nothing internal. Be sure to take a look at the brakes especially if you have disk. Depending on what type of brakes you have you may need to shim the caliper to get it centered on the rotor. If it isn't centered one pad may be rubbing and squeaking, fought that issue with some Willwood disk brakes with a Strange 12 bolt on my car.
LS1Tech Sponsor
With a Moser 12 bolt the first thing I'd look at is to see if the torque arm bolts back at the rear are tight. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Thanks everyone.
I also wanting to go with higher gears from 4.10s to 3.42s.
So I can actually use first 😂
What's the better gear to go with and what all do I need.
Went from stock motor to a pro charger and good internals.
Just figured that I should raise the gear ratio so I didn't spend all my time spinning a lot
LS1Tech Sponsor
3.42 Motive Gears
http://shop.brutespeed.com/Moser-R12...2B-12-Bolt.htm
Install Kit
Here are the parts that you would need. Bob
__________________
LS1Tech Sponsor
__________________
Thanks bob. Looks like you will be getting more of my business..
I bought the procgarger kit from my brother and he bought it from y'all.
And then I had to by all the pieces that he used on his next set up.
So thank you for your help
LS1Tech Sponsor
You're welcome. Thanks. Bob
__________________
