Mavns Quick Performance 9" Install.
Old 10-24-2016, 11:52 AM
"I MAID THEESE"
Mavn's Avatar
Default Mavns Quick Performance 9" Install.
Heres some Pics from my Quick Performance 9" Install.
Things I had to modify:
1: Torque Arm Mount was too wide and my TQ arm would NOT Line up so I had to grind it down.
2: I had to literally Cut 1 coil off of my 2" Lowerng springs because the spring Pirch was sitting too tall I Looked like I had a lift kit lol
3: Torque arm would NOT Fit in the tunnel so I had to take a Hammer to it lol
Now that its In its Fantastic. I need to modify the tunnel some more .
[non-sponsor pricing removed]
Pics:
Old 10-24-2016, 12:34 PM
Rise of the Phoenix's Avatar
I'm sure you were already testing it out this weekend.
Old 10-24-2016, 12:47 PM
"I MAID THEESE"
Mavn's Avatar
I put it in and went out and raced on it LOL
Old 10-24-2016, 12:52 PM
Only real way to test it out I suppose.
Old 10-24-2016, 01:20 PM
"I MAID THEESE"
Mavn's Avatar
Same way I Broke in my Motor
Old 10-25-2016, 10:37 AM
98cherrySS's Avatar
Even with all of the fitment work you had to perform, you're way better off than me and my crooked-assed MWC fab9 rear. Good job!
Old 10-25-2016, 12:22 PM
"I MAID THEESE"
Mavn's Avatar
Oh **** lol Mine isn't crooked atleast!!!!
Old 10-25-2016, 12:30 PM
"I MAID THEESE"
Mavn's Avatar
EDIT. I had to grind more. Was still hitting .. Ill jack it up tomorrow and take some picures!
Old 10-25-2016, 08:10 PM
unioncarpenter84's Avatar
To me that seems like a junk rear end if u have to smash the tunnel in that much to accommodate that rear end.
Old 10-28-2016, 02:57 AM
FIVEPOINT7's Avatar
When my T/A goes 9", it'll be a fab 9 from midwest. The only option that comes close in my eyes is an S60 with an S-trac.
Old 01-11-2017, 05:09 AM
bufmatmuslepants's Avatar
I mean you are cramming a monster rear end into a car it wasn't designed for, you have to expect some mods. I had to hammer my tunnel too.
Old 01-12-2017, 06:58 AM
Floorman279's Avatar
Ummmmm what? A mwc fab 9 isnt much bigger.
Old 01-12-2017, 08:05 AM
LS1Tech Premium Sponsor
MidwestChassis's Avatar
We actually have more room than most of the others because of our torque arm design.
Old 01-12-2017, 11:38 AM
01ssreda4's Avatar
Thats correct, its bigger then the stock rear but also a stock style torque arm adds another monkey wrench in the situation.
Old 01-12-2017, 12:22 PM
nmass399's Avatar
I've put two Midwest chassis fab 9's in and had no trouble at all. No modifying no beating just install it and go. I wasn't aware the stamped steel housings had these issues
Old 01-12-2017, 12:49 PM
MidwestChassis2's Avatar
This is happens because the only way you can fit a torque arm onto a stamped housing is to move the pinion closer to the passenger side and the mounting points closer to the drivers side.
This is an issue with all stamped housing of course some worse than others and why we mount our torque arm the way we do eliminating the stock style torque arm configuration.
Old 01-12-2017, 02:37 PM
Firebirdmuscle's Avatar
Same here, MWC went in without having to beat any of the tunnel in
Old 01-12-2017, 04:05 PM
These are the things you will notice when you purchase from a company that engineered their own product, install their own product, and use their own product.
Those reasons above are what sets us apart from companies that are just parts slingers. Not to mention we keep in contact with our customers, customers are and will always give valued feedback.
Old 01-12-2017, 06:39 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Every manufacturer can mess up every now and then, I'm not aware of any Moser fabricated rears going out messed up, but I'm sure it could happen.
Moser has been building fabricated 9 inch rears since 2007, they come with an excellent chromoly torque arm that is telescopic, and has plenty of clearance.
Contrary to what one vendor on here has mentioned, Moser's fabricated rear also comes with a drain and a large fill as standard equipment.
Moser is one of the few companies that design their own rear who also make their own center section and axles.
Moser's fabricated 9 inch rears do not come with brake line clips built on to the housing, but if you can live without brake line clips a moser fabricated 9 inch that isn't powder coated typically ships out the same week it is ordered.
http://shop.brutespeed.com/Moser-M9-...y-Complete.htm
If you order a Moser rear through Brute Speed, sway bar brackets come standard. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 01-12-2017, 10:32 PM
nmass399's Avatar
Good info thanks!!!
Quick Reply: Mavns Quick Performance 9" Install.
