Driveshaft recommendation - Page 3 - LS1TECH
Thread Tools Search this Thread
Old 02-04-2017, 08:48 PM   #41
Thank you so much launch, I think I'm getting it. I had my car set up like the second picture, parelel. No I'm setting it up so pinions pointing down instead of up.
onebadbowtie86 is offline   Reply With Quote
Old 02-04-2017, 08:56 PM   #42
Launch's Avatar
Quote:
Originally Posted by onebadbowtie86 View Post
I have the car on my 2 post lift right now. I raised the transmission as high as I could with out being in contact with the floor. Engine/trans is still sloped down 3*. I can't get the engine and trans sitting at 0* in this car.
So the transmission slip yoke is pointing down 3*, or -3* the driveshaft runs at 0* to my pinion that's pointing up +3 right now.
Your saying I should have the slip yoke/driveshaft running at the same -3* as the engine/trans to the pinion at 0*?
Leave the transmission as is at 3 degrees. Now just adjust your rear axle so the pinion is pointing down, rather than upwards, and then drive the car....
Launch is offline   Reply With Quote
Old 02-04-2017, 08:59 PM   #43
Launch's Avatar
Yes I think it will fix your vibration. If not then you need to assume there's something out of wack with your rear end or the transmission itself, rear end is always more likely
Old 02-04-2017, 09:32 PM   #44
Right now the trans is pointed down 3.5 and pinion is down 2. The vibrations still there, but it moved it higher in the mph it feels like. Should I try putting the pinion back up to 0 or lower it even more to -3 or -4?
Old 02-04-2017, 10:26 PM   #45
Launch's Avatar
Im outta ideas man. Without seeing it in person I can't get a grasp of how your driveline angles are exactly. You could try point the pinion down further but im starting to think the issue is elsewhere. What rear axle do you have? And how old is it?
Sure it's not rear wheel balance issue?
Old 02-04-2017, 10:50 PM   #46
The rear axle is a gm 8.5" with new moser axles, new bearings and a trutrac. 4.30 motive gears. I just pulled the diff out to install the new 1350 pinion yoke and set the pinion pre load. everything in the rear appears good? I ran it on jack stands with now wheels tires or brake drums with no difference.
I guess I'll just spend some time moving the pinion around tomorrow.
Old 02-05-2017, 07:48 PM   #47
I don't think my vibration is a driveshaft/pinion angle issue. Just tore into my t56 and I have the loose 5-6 gear on the main shaft. Thank you everyone for the help.
Old 02-06-2017, 06:12 PM   #48
Launch's Avatar
Hopefully that fixes it. Driveline vibrations and other difficult to diagnose problems can be frustrating as hell. I've had a good run so far with all my vehicles and not had any vibrations.
My tire shop couldn't even balance my Weld wheels because they didn't have the proper 5 lug attachment to clamp them down for balancing, they didn't understand how these wheels should be balanced, they were spinning them up and telling me they're bent as **** and to send them back, but I read the Weld Racing instructions and I knew the tire place don't know wtf is going on.. So I just took them and ran them on the car as is and without any balancing my car still feels 100% winding the speedometer right over.
If you repair your T56 and still have the vibration, all it could be left is something wrong with your pinion yoke, maybe it's been machined off center.. you never know these days. Personally I'd only run either a genuine Spicer, or a Strange or MW chromoly pinion yoke.
Old 02-07-2017, 01:43 AM   #49
Ya, this driveline vibe has been frustrating to say the least but I think This is the problem.
I dont think the pinion yoke is bad, I had a new spicer on my 8.5" when I rebuilt it a year or so ago, and I just installed a chromoly strange 1350 pinion yoke with no change.
Related Topics
Thread Thread Starter Forum Replies Last Post
chasing a driveline vibration.... C Murda Gears & Axles 33 11-09-2016 09:45 PM
What's your driveshaft? SCott5 Gears & Axles 18 11-22-2015 10:19 AM
Junkyard Swap 3.5 inch Aluminium Drive shaft for $26.38 -MMC -Metal Matrix Composite LS3 G Body Conversions & Hybrids 5 07-13-2013 09:38 PM
Inspecting a t56 out of the car. (chasing a vibration) ThoR294 Manual Transmission 19 03-24-2010 11:47 PM
Inconsistent vibration from 1500-2500 RPM ??? tylert14 LT1-LT4 Modifications 2 10-30-2007 11:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
