How much can a stock ws6 rear end take ?
LS1Tech Administrator
Received 1,468 Likes
Exactly correct.
And if you want the long answer, here's a ton of evidence with lots of detailed information:
https://ls1tech.com/forums/gears-axl...ock-7-5-a.html
It's the same rear, other than gear ratio. It's just that the A4 is generally much easier on the rear (unless you get massive wheel hop) than the M6.
Check out the link above. Lots of real world data there.
Depends on what tires you go with. Regular ole street tires, it should be fine (there are exceptions). DR's or Slicks, you're on borrowed time.
I've managed to get 228k on my 10-bolt and it's an M6 car. It's only saving grace has been the tires. They slip before the rear is really being stressed.
