Rearend leaking - LS1TECH
Rearend leaking
Thread Tools Search this Thread
Old 02-23-2017, 08:58 AM   #1
TXCatfish's Avatar
Default Rearend leaking
Just noticed my rearend differential is leaking. I may have place the jack in the wrong place when sitting the car on jackstands.
Just wondering if anyone has had this happen. Can't really tell that the cover is bent, everything looks fine too me. I put some silicone on the bottom but it still leaked. I put a little more on this morning..
TXCatfish is offline   Reply With Quote
Old 02-23-2017, 10:12 AM   #2
The cover can get bent. There should be silicone as a seal.Just take it off and check it out. It might be a good time to change the fluid. You could always order a aluminum cover.
2ToeRacing is offline   Reply With Quote
Old 02-23-2017, 10:22 AM   #3
TXCatfish's Avatar
Okay hopefully it's just the cover. Like I said I couldn't really tell it was bent and wasn't sure if this has happened to anyone after jacking the car up.
I've jacked my car up a thousand times and never had a problem.. I may just try to seal it with silicone just to get me by the next couple weeks while racing and find a aluminum cover online
Thanks!
Old 02-25-2017, 08:35 AM   #4
01ssreda4's Avatar
Yeah pull it, and reseal it or replace the cover. New steel ones are available on ebay for cheap.
01ssreda4 is offline   Reply With Quote
Old 02-27-2017, 11:24 AM   #5
TXCatfish's Avatar
My little patch job seems to be working for now. I will probably pick up another steel one of ebay.
Now for bigger problems I may have broke the sprague in the torque converter Saturday. That's seems about right, one week before the first race.
Old 03-10-2017, 10:34 AM   #6
SteveC's Avatar
Location: Poway, Ca. where God and the sun always shines
Is it a pinion seal, or on the cover side?
SteveC is offline   Reply With Quote
Old 03-10-2017, 11:22 AM   #7
TXCatfish's Avatar
It is the cover. Little silicone fixed it up.
Related Topics
Thread Thread Starter Forum Replies Last Post
1971 TH350 Leak 71Pontiac Automatic Transmission 3 06-27-2016 01:13 PM
Carb leak? baronsmith98 Carbureted LSX Forum 1 04-08-2016 11:09 AM
looking for a 9 inch rearend! dlross General LSX Automobile Discussion 8 06-10-2010 07:46 PM
9" rear end fluid leaking out the end of axle tubes onto brakes??? c5formula Gears & Axles 11 01-11-2010 04:05 PM
10 bolt rearend leak, easy to fix? ibanez7 Gears & Axles 7 04-04-2007 01:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
