How to Identify a F-body 12-bolt?
Old 11-09-2016, 07:23 PM
earnhardt12's Avatar
Default How to Identify a F-body 12-bolt?
Like the title say's I need help identifying a 12-bolt made for the F-body I picked one up off craigslist for an amazing deal but I don't know who its made by the only real casting on it is a number on the passenger side axle tube housing and a ME003 in the carrier housing any help would be great
Old 11-09-2016, 07:45 PM
AgFormula02's Avatar
If you mean for a third or fourth gen, then you are looking for a specific shock and most importantly torque arm mounting areas.
Should have provisions for the 2 bolts and machines areas where the TQ attaches to the housing.
Old 11-09-2016, 07:51 PM
I know its for a f body its got the torque arm mount spring mounts and all I watched the guy unbolt it out of a 1998 T/A I was just wondering who the manufacturer was ex. Strange or Moser after looking at pics on yahoo I'm pretty sure it's a Moser by the way the torque arm mount is cast but still would like to know if anyone knows by the ME003 cast in the housing
Old 11-09-2016, 07:59 PM
ME: Moser Engineering
Old 11-10-2016, 05:43 AM
Thanks man that helps a lot, Picked the thing up for $500 complete with drilled and slotted rotors they guy was an import guy had bought the T/A to put the ls1 and t56 in a 300zx to make a drift car said he bought the whole car for $500 with title wish i could have found it first lol
Old 11-10-2016, 08:16 AM
MidwestChassis2's Avatar
Strong suggestion before putting that 12-bolt directly in is rebuild it first to save yourself some possible hassles. Change the axle bearings from ball bearing to tapered and put in a new ring and pinion. 12-bolts are prone to ring and pinion noise over time and not knowing the age or miles on the housing it may be due plus a tapered bearing is better choice for a street driven vehicle. If it already hasn't been changed or ordered with tapered bearings.
Once you do that you'll be like new and ready to rock with a good rear end.
Old 11-10-2016, 01:31 PM
Thanks for the info what gear oil would you run in it synthetic or conventional and what weight?
Old 11-10-2016, 03:20 PM
Lucas 80-90 is what we recommend.
Old 02-19-2017, 09:27 PM
nastyiroc's Avatar
How do you get a 12 bolt to not whine?
Old 02-20-2017, 01:47 PM
blackandgold's Avatar
Don't drive it
There are a solid number of people on LS1Tech with quiet 12 bolts, mostly behind an A4, but with quality parts and the correct break-in cycle you should be fine unless you're constantly launching 500 wheel HP on slicks.
Quick Reply: How to Identify a F-body 12-bolt?
