Factory 10 bolt 2001 SS questions. - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 02-25-2017, 05:03 PM   #21
Quote:
Originally Posted by 01ssreda4 View Post
Auburn is gonna have clutch cones, pushed together with springs and require oil additive so they slip and engage correctly. A torsen or true-track gear driven posi is pictured below, and requires no additive.
I believe the stock rear in my car is a Torsen but I've heard they are weak.
I will be doing a lot more canyon carving than drag racing type driving so whatever I get needs to work well in the corners but I want fairly strong for if and when I do make an occasional hard launch.
You should see the roads out here, great fun for sports cars and motorcycles. I live way out of the city in the mountains and the twisties are everywhere out here.
y2keglide is offline   Reply With Quote
Old 02-26-2017, 07:50 AM   #22
01ssreda4's Avatar
Quote:
Originally Posted by FirstYrLS1Z View Post
The little 10 bolts(whether Auburn or Torsen or Eaton) are fine when they're not driven/used in an abusive manner. How many millions are out there that are doing fine,Camaros,Firebirds,S10 trucks,S10 Blazers.
Dont forget Astro and Safari vans as well.
01ssreda4 is offline   Reply With Quote
Old 02-26-2017, 08:23 AM   #23
FirstYrLS1Z's Avatar
Thanks,I DID forget those !
FirstYrLS1Z is online now   Reply With Quote
Old 02-26-2017, 10:16 AM   #24
01ssreda4's Avatar
Only reason I know is because I had one in high school and busted the 10 bolt!
Old 02-26-2017, 10:28 AM   #25
Quote:
Originally Posted by y2keglide View Post
This isn't the Aubun posi unit though and this gives me pause "10 Bolt Eaton Style Clutch Posi Unit". There are good reviews but what does "Eaton Style" mean?
I'm guessing a China made knock off which may or may not be fine, China made quality is all over the place. I may have to find out more about it, wonder if a true Eaton brand part is made here still?
Yeah it was,I bought them and installed both and they were Alburn pro's (cone type)and they cost me about 4-600 bucks each. I put the first one back in 98. I just replaced it again in 2016 with new gears.
2ToeRacing is online now   Reply With Quote
Old 02-26-2017, 11:37 AM   #26
Quote:
Originally Posted by 2ToeRacing View Post
Thats a great deal. I redid the rear in my S-10. I bought a Alburn carrier,3.42 gears,install kit. It was about 900 bucks.
I meant the one I posted a link too that seems like a good deal wasn't an Auburn not yours and the one in the link says "Eaton style" so I wonder who actually makes it.
Old 03-07-2017, 07:27 PM   #27
I wouldn't buy the Auburn, unbalanced piece of junk IMO. I'd get some thing that strong and will last that is BALANCED so you don't get vibrations at highway speeds. I bought a new Auburn, installed it and WALAAA constant rear vibrations that started around 45 mph and just got worse the faster I drove. The only change was the carrier. Had the carrier in for 2k miles and the cone clutch wear was REDICULES. Good Luck I went back to the Torsen, car is smooth as azz now.
RockinWs6 is offline   Reply With Quote
Old 03-07-2017, 11:18 PM   #28
LS1Tech Administrator
RPM WS6's Avatar
My experience has been very different from RockinWs6 on this particular issue. I've had no premature wear or vibration issues of any kind with the stock Auburn in my '98 or the aftermarket Auburn in my '71. I've been happier with them than the Torsens for sure.
RPM WS6 is offline   Reply With Quote
Old 03-08-2017, 12:56 AM   #29
The Auburn is way stronger for sure but my experience was terrible but it wasn't a OEM unit, I bought it from Summit I think. I believe when they supply OEM factory units more workmanship goes into the units (LIKE BALANCING) When I pulled it out for sure there were no signs of it being balanced in any way and the oil was full of metal from the cone clutches. Also with that unit in the car the car handled very stiff in the turns. Putting the Torsen back in solved all the issues. I never tested the Auburn with a torque wrench to see how hard the cone clutches were loaded but it must have been very high to effect the steering.
The Torsen is broken but its jammed up broken, so far I've been getting away with it. Last fbody was broken the same way and I never had trouble with it except its very very noisy. The axles are basicly locked up to each other. I also had a torsen in another fbody that broke open, only one drive axle working. Torsen is about worthless for any kind of real power. I'm good at getting power out of the engines so unfortunately the carriers take a beating. There are good carriers out there but you're talking 500 plus for a good one. If I have to change it again I'm buying the Eaton posi, its without a doubt the best one out there right now that I know of. Your opinion may vary.
Old 03-08-2017, 08:02 PM   #30
Super Hulk Smash
JakeFusion's Avatar
TrueTrac for the 10-bolt would be what I'd do if you need to replace the differential.
https://www.summitracing.com/parts/d...a317/overview/
JakeFusion is offline   Reply With Quote
Old 03-09-2017, 03:33 AM   #31
Thats a good one for sure.
Old 03-09-2017, 08:30 AM   #32
01ssreda4's Avatar
True track is a junk Chinese posi. That being said I've owned one and so have lots of others and had good luck. But don't expect miracles from it, accept it for what it is.
Old 03-09-2017, 05:07 PM   #33
I Like the trutrac in my 8.5", But I was a little disappointed it had "Made in Taiwan" stamped on it.
So not Chinese, Taiwanese lol.
onebadbowtie86 is offline   Reply With Quote
Old 03-09-2017, 05:56 PM   #34
I didn't know they were built there, the Eaton I thought were made in US. Guess its not the same carrier I know from past years. I should know better, everything today is over priced crap. FK it, put a spool in it and suffer the tire wear. That's all I had in my 68 Formula S Barracuda and that car was BAD AZZ, probably the nastiest car every come out of Detroit. I drove it on the street for years without any real trouble except it wore the tires badly and wouldn't turn LMAO.
Old 03-09-2017, 06:34 PM   #35
Quote:
Originally Posted by RockinWs6 View Post
today is over priced . FK it, put a spool in it and suffer the tire wear. That's all I had in my 68 Formula S Barracuda and that car was BAD AZZ, probably the nastiest car every come out of Detroit. I drove it on the street for years without any real trouble except it wore the tires badly and wouldn't turn LMAO.
That's fine for a hot rod or drag racer but won't work for a canyon carver like I plan on having, it's got to work in the corners well whatever I end up with.
More confused now than when I started with this thread. lol
Old 03-09-2017, 11:28 PM   #36
There is another Eaton with a clutch setup in it for sale someplace because about 8-10 years ago I was eyeballin it to put in one of my TA's. It a good carrier, If I can find it i'll post a link.
Old 03-10-2017, 08:10 AM   #37
https://www.summitracing.com/parts/etn-19599-010 <This is what I would use. 500 bucks and worth every penny, much better than the Auburn or the TrueTrac IMO for a street car. The worm gear design in the TrueTrac is weaker than the Eaton Posi IMO. Plus when you rebuild it quickly and easily. If you break the TrueTrac its probably damaged beyond repair.
Here is the Eaton application guide http://www.eaton.com/ecm/groups/publ.../ct_128302.pdf
Old 03-10-2017, 09:10 AM   #38
Super Hulk Smash
JakeFusion's Avatar
Could always put a spool in too? If you can drive it on the street with the wheels locked together. That'd probably be the strongest 10-bolt you could build.
And yes, TruTrac is Chinese. But it's a good differential for a street car. It's more of a "road race" type of differential that may be no better than the Auburn in terms of durability.
The best differential is the S-Trac or Wavetrac. Which is a similar design to the TruTrac. But they don't make for a 10-bolt.
Old 03-10-2017, 09:27 AM   #39
I drove my 68 Barracuda around for years with a spool. Chopped the tires up badly and on twisty roads it was scary. Straight line it was killer and never broke.
OF COURSE a spool on the street is for limited use only!
Old 03-10-2017, 11:54 AM   #40
The Eaton linked in post #37 is my preferred carrier,2nd preference is the Auburn. I have an auto so my carriers don't get abused anyway.
Related Topics
Thread Thread Starter Forum Replies Last Post
Selling all my parts- built lt1 t56, full bmr, tons of LS stuff, QTP LS headers, etc carguyshu Parts Classifieds 98 01-22-2017 11:18 AM
gears? 3.73, 3.90, 4.10, oh my JadXtreme Gears & Axles 33 07-14-2015 10:23 AM
28" with 4:56 Pros and Cons M6 questions scotty2000ss Drag Racing Tech 28 05-23-2015 04:40 PM
Yeah yeah, I know, but 10-bolt build behind an A4 JakeFusion Gears & Axles 56 03-13-2015 12:48 PM
Where are my M6 10 bolt 3.90 gear guys at??? hurley711 Gears & Axles 58 07-25-2011 08:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
