Factory 10 bolt 2001 SS questions. - Page 3 - LS1TECH
Thread Tools Search this Thread
Old 03-10-2017, 12:38 PM   #41
The True-Trac needs GOOD synthetic lube. its same tech as a Torsen for a bit less money, and it is a bit stronger than the Torsen diffs, just not as good at balancing the power.
I've run them in jeeps and had decent results, One thing,,, when you un-pack it, TORQUE the bolts. I've put in 3 and 2 had loose bolts right out of the box.
Note, none of the torque sensing gear drive diffs like big torque, RPM's don't bother them.
A diff cooler is recommended if your putting big power through them and using them hard at all.
If you can tolerate the clunking a regular detroit locker works well in road racing, you do have to learn to lift off the gas slightly as you turn in to allow it to release through the turn, as soon as you gas it you get lockup like a spool.
pdxmotorhead is offline   Reply With Quote
Old 03-10-2017, 01:01 PM   #42
Quote:
Originally Posted by FirstYrLS1Z View Post
The Eaton linked in post #37 is my preferred carrier,2nd preference is the Auburn. I have an auto so my carriers don't get abused anyway.
LOL every Torsen I broke was on the 1-2 shift auto trans WOT big tires. That crunching nasty sound as those worms break.......... 1st time it happened the car lurged-banged but still moved ok, was a few miles later I realized what actually happened.
RockinWs6 is offline   Reply With Quote
Old 03-11-2017, 11:31 AM   #43
01ssreda4's Avatar
Quote:
Originally Posted by JakeFusion View Post
Could always put a spool in too? If you can drive it on the street with the wheels locked together. That'd probably be the strongest 10-bolt you could build.
Can you post a link for a 10 bolt spool? I know they make mini spools but everything Ive seen regards them as junk.
01ssreda4 is offline   Reply With Quote
Old 03-14-2017, 09:01 PM   #44
Super Hulk Smash
JakeFusion's Avatar
Yukon Mini Spool. It's probably junk.
https://www.yukongear.com/productdet...x?ProdID=13327
JakeFusion is offline   Reply With Quote
Old 03-15-2017, 09:13 AM   #45
01ssreda4's Avatar
I have no actual experience. Lots of people say they can snap factory axles just turning in parking lots and doing normal driving stuff and with a c clip axle that means there wont be much holding your wheel in the wheelwell. Seems too iffy for me to ever suggest.
Related Topics
Thread Thread Starter Forum Replies Last Post
Selling all my parts- built lt1 t56, full bmr, tons of LS stuff, QTP LS headers, etc carguyshu Parts Classifieds 98 01-22-2017 11:18 AM
gears? 3.73, 3.90, 4.10, oh my JadXtreme Gears & Axles 33 07-14-2015 10:23 AM
28" with 4:56 Pros and Cons M6 questions scotty2000ss Drag Racing Tech 28 05-23-2015 04:40 PM
Where are my M6 10 bolt 3.90 gear guys at??? hurley711 Gears & Axles 58 07-25-2011 08:49 PM
Are Torsen and Auburn posi's interchangeable? Formula413 Gears & Axles 7 11-11-2008 07:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
