3 channel to 4 channel
There is no tuning out to make one work with the other so if you want it to work properly you will have to hook it up completely.
To hook it up completely you will have to pull the 12 bolt apart and your ten bolt apart. You will have to reuse your reluctor wheels but purchase Strange adapter. You will also have to reuse your brake backing plates and tin shields as they are different.
You will also have to pull your stock axles apart as well as the 12 bolt axles to do all of this which means new bearings and labor if you can not press these on and off yourself.
I have pics of all those parts he is talking about in this thread below. Pain but can be done.
https://ls1tech.com/forums/gears-axl...t-install.html
