Adjusted my DSL today for exhaust clearance and it rubbed the Driveshaft
So I decided to get rid of a little annoying issue with my exhaust touching the DSL loop. I didn't jack the car up. Just reached under, put a few more washers to space it down and went. Well I noticed on my test drive the exhaust was not longer contacting the crossmember of the DSL.
But I heard a ting ting noise. A new noise.
So I got home and adjusted the DSL. Ran it for a min and revved to see if I could locate the noise. Unsatisfied with that, I jacked it up. My adjustment had made it worse by pulling it closer to the driver side.
When I jacked it up, I was able to get my fingers on the top of the loop and found it was basically touching the driveshaft on the passenger side (my blindspot when it wasn't jacked up).
I saw a faint line around the driveshaft and found a small amount of metal dust. But I could not catch my fingernail on the visible line. So it was not grooved.
Do you think the driveshaft is okay? It's a heavy wall 3.5" aluminum shaft. It didn't get hot. And only made contact a couple of times at low speed from what I could tell.
I recentered it. And it has clearance. Not a ton. But it's cleared on both sides and on top. I need to pull it back up, but then it'll hit the Kooks True Duals. So I may swap to a new DSL to avoid the issue.
Lesson - don't shortcut things.
Thanks for your order you won't be disappointed. Keep in mind the loop goes behind your fuel lines to be bolted up properly. Most do not do this and think it doesn't fit properly.
Here is an installed picture directly from our web site to show proper fitment with plenty of ground clearance.
On my mwc break in , I rubbed mine on my loop as well. I thought the noise were my rear brakes because they were new and had a rough time getting caliper on disc . So I just thought my pads were rubbing down. Find out later my pst got grooved pretty good. I took it to a ds shop where they sanded it and checked the depth of the gouge. It looked real bad but he came back and said some small number and that he checked and it balanced out ok. Pst 3.5 inch uses 120 wall. All.fine but still sucks
I haven't got under there to look. But are there body mounts that hold the line? Can I just unbolt those and pull the line away from the tunnel enough to slide this in? Or is it move involved?
And when I unbolt the ujoint straps, should I replace those? I always have since it's like $5-6 for them but didn't know if it was needed.
Unbolt what is needed and slide it behind them and bolt everything back in place. As for hardware replacing I have a habit of always buying new no matter if they where used or not. May be a bad habit but it is a habit I have done my entire life.
Carl Loder
