best fluid for the diff?
Old 09-16-2004, 08:33 PM
LeddySS98's Avatar
Default best fluid for the diff?
I remember reading about this before deploying, but I have after getting back, I have forgotten the answer, and cant find the thread...
What kind/brand/WT of gear oil is best to go with on the rear diff...
98 M6, with the rusty looking cover, I think that is the Torsen but I could be backwards on that one too...
Old 09-17-2004, 01:51 PM
Brandon_TA's Avatar
I used Royal Purple 90W + addative... Atleast thats what the shop use's on it when they change it for me.
Old 09-19-2004, 10:58 AM
Moderator
jimmyblue's Avatar
The fluid wants the special limited slip additive if it
is not the Torsen (like if you got an Auburn unit,
which I think was something more common in '98
than later). There should be a little tag on one of
the diff cover bolts if it's a factory Auburn I think.
The Torsen doesn't care.
I think the best way to check Torsen vs Auburn
is get the wheels off the ground, put it in neutral
and slowly turn one tire; if they both go in the
same direction it's a posi type and if they go in
opposite directions it's a Torsen (or a limited slip
with no preload grip left).
Old 09-21-2004, 02:00 PM
sawedoff's Avatar
Try this, I've been using it and I'm a believer.
http://www.neosyntheticoil.com/gearoil.htm
