ABS light and 9"...
ABS light and 9"...
I'm considering a 9", after seeing all the horror stories from pretty much all the other rear ends. I hate - and I mean HATE - having idiot lights burning on my console. Will my tuner be able to disable the ABS light, or is there another trick to getting the light turned off? (I need 3 channel, so 4 channel isn't an option)
Originally Posted by SupahRich
I know this post is a few months old... but curious if the newer version of HPTuner's allows you to turn off the ABS light?
Originally Posted by Turo
no it does not. i dont think the pcm controls the abs, i could be wrong though.
Wonder if there's a way to find which wire going to the gauge cluster triggers the ABS light to turn on? If not then there's got to be a way to disable the light other than removing the bulb from the cluster.
