Could built 10 bolt for street racing only?
I know that 12 bolt or 9'' is better for track but if I don't intend to enter the truck only street racing!! Could I built 10 bolt to make it strong to hold around 450hp rear wheel
As long as you only race from a roll, probably no problem. But do a search, lot's of guys have exploded their 10 bolts with stock power just by powershifting a stick.
I wouldn't recommend counting on it.
likes the others said.. stay away from nittos or E/Ts and you'll be ok.. the following like is what my 3rd 10bolt failure has done to my gears... https://ls1tech.com/forums/gears-axles/230671-killed-rear-end-wifes-not-amused.html
Plenty of guys and gals on this board are successfully racing w/the 7.5 10 bolts. However, they've beefed them up a little w/better axles, better posi-units, welded axle tubes, girdle type rear covers and hardened bearing cap stud bolt kits. Many of these rears are surviving 450 hp. Automatic equipped rears tend to live longer than M6's, but some stick people are making them survive, too. Again, the stock axles are the weakest point in the 7.5. Sidestepping the clutch off a 4000+ rpm launch w/sticky tires and a sticky starting line will twist a stock axle into 2 pieces like a hot knife cuts thru butter. Very good article a few months back in "Chevy High Performance" on the 7.5 rear. (May-'04). I've had very good luck with both my '99 M6 4.10 equipped SS (over 65 quarter mile passes and 11,000 miles, and my '02 A4 SS w/3.23's and Vig 3200 converter. Absolutely no problems. Another key to making these rears live: Keep the synthetic lubes out of them. (IMO). WJ.
Moderator
I put Redline in after the T-2R/3.42s swap.
Don't know EXACTLY why, Jimmy. But the old buck who sets up all my gearsets told me that: 1. they will stay quieter way longer when abused. And,2. they will live longer. He has set up, virtually hundreds of rears, so I listen to his knowledge and successful set-up experience. Also, I believe that CHP article says basically the same thing.....How're you doing? See you've posted some real nice times with your convertible! Someday I have to talk to you about part-throttle shiftpoints.....Best wishes. WJ.
Originally Posted by JackZ28
Even a built 10 bolt is not good for much more than 400 at the wheels.
Brandon
You really think pulling into the parking lot at 10 MPH broke it? No way. That thing was in the process of coming apart for other reasons way before then.
Originally Posted by m1key99WS6
I broke my 10bolt pulling into a mexican restaurant "ON THE STREET" going less than 10 MPH.
Do what you want, the 10 bolt is a POS.
Cheers.
Cheers.
