Ford 9" in a Camaro?
Moderator
I have the chance of getting a Ford 9" cheap. Are there any modifications taht need to be made to fit on a 99 Camaro. Currently have the stock 10 bolt.
Has to be narrowed, new narrowed axles, axle housing ends changed, control arm, spring mounts, and torque arm mounts welded on and in the correct location.
Unless this thing is out of an f-body, you are looking at a ton of modification work.
If it is cheap enough, you still might want to get it just for the pumpkin, gears, and posi. Then sell the rest to someone else and buy a Moser or Strange housing and axles.
