Please help i've made a big mistake "Moser 12 bolt"
I've press on the bearing onto both of the axles without the brake backing plates. Could anyone tell me if I could press back off the bearings or would I have to order new bearings/axle? I wish I would have gotten the information from fbody.com "install 12 bolt Moser" sooner!! A newbie still.
You can get them off, but not sure if they will be any good afterwards, depends on whether you can get a bearing puller on the inner race or you have to pull on the outer race. It will probably take a long set of threaded rod and a bearing puller.
Good luck !
Good luck !
Good luck !
Good luck !
You need what is called a bearing separator. Like this:
http://www.jackxchange.com/products/W93275.cfm
This goes behind the bearing and threaded rods go into the faces of it. You can then put a metal strap between the two threaded rods, and a hydraulic jack between the strap and the end of your axle. As you pump on the jack it will push the axle out of the bearing (since the seperator/rod/strap assembly is holding it in place).
You could also take it to a 4x4 shop and have them take them off for your. They are usually very used to removing and replacing axle bearings.
