9" with Alum. center section for street?
Just like the title says, How would a 9" with an alum center section be on the street? The car is not a daily driver, but a weekend/track car so I want to keep it light and was wondering if anyone uses the alum. one on the street?
Dan
Dan
Kleeborp the Moderator™
Sure, aluminum can be used on the street, but it will deflect more, which is why people do not recommend them for daily driver purposes, because you'll most likely have premature bearing wear. Not saying it will happen, just saying it could. It sounds like for your purposes, you'd be fine. I just wouldn't use one on a daily driver that sees a lot of miles. You'd probably have to rebuild the rear a few more times than you'd like.
Steve
Steve
Originally Posted by Mark98SS
I went with the cast iron center thinking since it's stronger & on an F-Body the center has the TA attached to it so there is more stress than usual.
Steve
Steve
14 Second Truck Club
When you apply power to the rear the ring gear doesnt want to turn because of traction from the tires. So the first reaction of the pinion when it cant turn the ring gear is to twist and push away from the ring and upward. An iron case is better at holding the pinion exactly where it needs to be. Also, the 9" pinion is held by 3 bearings rather than the normal 2, so deflection is still controlled somewhat. You can use a iron pinion support with the aluminum 3rd member, which will help control the deflection some. I would say that an aluminum center would be fine for about 500 whp for a good while. The more power you put to it, the less time it will last.
Originally Posted by LOnSLO
The torque arm doesn't attach to the center section.
Shows you what I know, looked like it does, I'm pulling the center next weekend so I woulda found out. Oh well, another theory shot in the ***...
