Is my rear end going to go soon?
I race on a very regular basis. I have a 99 A4 (mods in sig) with stock rear and ET Streets (although I had the axles and bearings and seals replaced 8k miles ago (and put strange 3.73s in).
When I am cruising at about 60 mph and let off the gas: When the converter unlocks I hear a quick louder whiney noise, followed by my normal whine. The rear is not clunking and doesnt seem to change around a turn. It is mainly on decel when I hear it, accel = nothing. It is when it downshifts.
I am not going to race the car anymore untill I get a 9 inch or 12 bolt (whatever people tell me is best to get for the $$) but Will I be ok on the street for a few more months probably?
What do you think is the probme? I assume it is the rear end but do you thinik its serious?
Thanks,
Brent
Thanks,
Brent
Originally Posted by t1blackout
how loud is a 12 bolt? bearable for a daily driver / weekend track car?
if it is properly set up it should not make any noise. I have had several 3rd members built and heard the differance between a good setup and a bad one. The 12 bolts are the same, the only noise you will heard it s the diff you dicide to go with. I would look around alot before buying a rear, there are very very good places to get one, also with a warranty, I would recomend a place but there not a sponcer(bad taste) so if you want the name PM me. Check out the truck stuff it is built for serious tq so that could be another deriction to go.
