Grenaded the 12 bolt this weekend.....
Old 11-09-2004, 10:44 AM
1fastWS6's Avatar
Default Grenaded the 12 bolt this weekend.....
Made 2 passes with it dead hooking launching at 6200 rpm. Third pass dumped it and it just went "pow" and didn't move. Looks like the spider gears exploded and took out the ring and pinion too. See attached pic. This was a 800# Eaton Pro unit. Looks like I'm going to need new spider gears, springs, side plates, and a R&P. Hopefully the posi case isn't cracked too.
Anyone have any tips on rebuilding the Eaton? Do I need special tools to compress the springs? Any other advice for making it stronger BESIDES a spool.
Old 11-09-2004, 12:04 PM
gomer's Avatar
Damn.... that makes me want to
I was starting to overlook the howling the rear makes because it has been holding up good... is yours the 33 spline stuff with the heavy duty posi like mine? I'm ordering a set of 4.56's for mine this week and having a really good rear guy go thru the whole thing when he sets them up.
Old 11-09-2004, 12:12 PM
1fastWS6's Avatar
Yep, 33 spline, 800# posi, good setup, everything. The gears had been getting noisy but that's not unusual after a bunch of high rpm dumps on slicks.
It stripped EVERY tooth off both of the small spider gears.
I recently switched from a 26x11.5x16 ET Street on a 8" rim to a 26x10x15 ET Drag on a 10" rim and all I can say is that the traction difference is night and day better. Probably why it only lasted 4 passes after switching tires.
I'm looking at the heat treated U.S. Gear spiders for a replacement IF (big if) I decide to put it back together.
Old 11-09-2004, 12:32 PM
Ravenous T\A's Avatar
M6 + 12Bolt=Boom, I have heard of alot of 12bolts getting trashed with M6's, Wonder if the 9" would be a better choice???
Old 11-09-2004, 12:38 PM
1fastWS6's Avatar
Well, the only stronger option would be a 9"/locker or 9"/spool combo. Even if I did have a 9" with a clutch type posi, this would probably still happen.
Old 11-09-2004, 02:49 PM
matts22's Avatar
Man that sucks. With all of the whining problems and now more and more are breaking with M6's, I am leaning towards getting a 9 inch with a locker when it's time for a new rearend. You could always try a soft locker (Pro Stock John has one)...I hear they are quieter and less of a hassle on the street but still very strong at the track. But I don't know if they make these for 12 bolts--as far as I know, only 9 inches.
Old 11-09-2004, 03:10 PM
1fastWS6's Avatar
Yes, this does suck. I haven't seen a "soft" locker for anything but the small 30 spline axles.
Old 11-09-2004, 03:52 PM
SlickVert's Avatar
Sorry to hear that!
I also broke the spiders out of my 12 bolt Moser with the same setup launching at 4,000 on a 315/35/17 Nitio.
Old 11-09-2004, 04:10 PM
Ryan02SS's Avatar
I plan on putting a Detroit Softlocker into my 12bolt. I run them in my Wrangler's rear and front diff's and once you get used to them they are awesome, even driving on the street everyday. Almost indestructable strong to boot.
Old 11-09-2004, 04:11 PM
1fastWS6's Avatar
Ryan, who has one for a 33 spline axle?
Old 11-09-2004, 04:18 PM
gomer's Avatar
I want to know this too... I'm having my 4.10's swapped for 4.56's in the next week or so and I'd like to stick one of those in there.
Old 11-09-2004, 04:54 PM
1fastWS6's Avatar
Here we go Gomer.....http://www.tractech.com/Products.htm#locking
Detroit TrueTrac
PN: 914A575(PA) 33 spline, 4 series, 12 bolt
$405 from Randy's Ring & Pinion
Wish I knew someone that has been throwing some regular abuse at one of those units to see if they hold up well before buying one though.
Downside is that it's not rebuildable.
Old 11-09-2004, 05:12 PM
1fastWS6's Avatar
Found some more interesting info on the TrueTrac....
Apparently the angle of the splines for the 33's only matches Moser axles. Good for us, bad if you have a Strange 12 bolt.
Old 11-09-2004, 05:51 PM
matts22's Avatar
Are you sure that this is their soft locker? I thought the soft locker was just an option you could get with the regular detriot locker. Plus, it says that this "truetrac" is for commercial vehicles. I honestly have no idea, but just making sure you know what you are getting if you are going to buy it. It might be worth a call to tractech. But if that is right, that may be exactly what I want--a 12 bolt which weighs less and eats less power, with the strength of a locker 9 inch. Also, check out powertrax.com (may be another option). That is another option for a differential. Or even call Randy's, I'm sure they know what is best. Just my 2 cents.
Old 11-09-2004, 07:13 PM
racer88's Avatar
Eh my Old Man did the same thing and he was puttin down 390 RW at the time, M6 too
Old 11-09-2004, 07:20 PM
WJ SOM SS's Avatar
WS6: Just out of curiousity, how many miles and how many 1/4 mi. passes on the 12 bolt you just lost? Thanks. WJ
Old 11-09-2004, 08:15 PM
jerflash's Avatar
i was looking at getting the true track when i do a 12bolt
and i dont want a crap moser i want a strange
that would suck and stupid if they olny fit moser axles
that does not mack sence
Old 11-09-2004, 09:04 PM
HumpinSS's Avatar
This doesnt make any sense you can purchase an 33 spline eaton posi and it will fit the moser or the strange 12 bolt so why would this exclude the true trac
Old 11-09-2004, 09:08 PM
Restricted User
NOSjohn's Avatar
One word - SPOOL.
Old 11-09-2004, 09:11 PM
tump's Avatar
I just finished replacing my spidergears, the exact same thing...about 5500 rpm with ET streets.You will need to disassemle the rear and clean it out with brake cleaner and run rags through the axle tubes to get all of the shavings and gear bits out,Dont forget.
Quick Reply: Grenaded the 12 bolt this weekend.....
