3 channel to 4?
3 channel to 4?
I have a 3 channel wiring set up, but swapped to a used 4 channel moser rear. What should i do to retain the 4 channel, or should i just forget it?
Any suggestions...
Any suggestions...
if your car is set up for 3 channel ABS but the rear is a 4 channel you could build your own ABS setup with a reluctor ring mounted on the driveshaft. I posted a link to it on one of the last pages of the 8.8 post thats is stickyed in the top of this section.
