LPE drive shaft and moser
jus had my moser put in...everyone said i would need a napa 447 ujoint. bbut the funny thing is that my ujoint fit perfectly.... is this right?
btw I have a LPE 3.5 driveshaft....
thanks!!
thanks!!
well im wondering if im getting the noise..becausse the wrong u joint is on..plus i find it fishy..why everyone and there mother...gets a different ujoint..with a 12 bolt..and mine jus happens to fit??? i guess i was thinking i was getting noise..because it may be too tight!
does it just fit or does it fit right? The stock u-joint will fit in a 1350 yoke but it will have some side to side play and you will be able to see how the cap is too small for the u-bolt that holds it in. Does your new rear have u-bolts and nuts or straps and bolts like the stock rear?
