9" W/ a Spool
If there's a remote oil fill setup that would be handy but not necessary. The oil plug is on the left side behind the TA mount. Only way to fill it is with a squeeze bottle & flex tube, even then it's a PIA. I took the axel assy out of my car this weekend to change the diff, ran out of time & motivation this afternoon, I'll fill mine before installing the TA mount & before hanging the axel back in the car.
With a spool there's no moving parts & equal power to both wheels but don't drive it in the rain.
the oil fill option is good. it's a bung welded on top with a screw off cap that's about the size of a silver dollar. much bigger and more accessable than the factory type and location. it's welded to the top of the pumpkin. for oil and drain plugs it's $70 from Moser. you'll be hard pressed to break a spool, as that's what guys with over 2000 hp have. you will notice it making sharp turns, so hope you have power steering still! fyi, a lot of guys run them on the street, but most who do enough street driving, 5000/yr+, will opt for the Detroit Locker. it's supposed to hold well over 1200hp/tq.
later,
Dave
sending you a pm.
later,
Dave
sending you a pm.
The fill is a waste unless you are changing gears all the time, the drain is a much better option I have no problem filling mine with some rubber hose on a gear oil bottle.
You can get drilled/lightened axles, saves quite a bit of rotating weight. Aluminum center section will save some weight. The 9" in my other car had a lightened spool, 35 spline drilled/star flanged axles, moser aluminum center section and only weighed ~25 more pounds then the 10 bolt and I bet the rotationg weight wasnt much more. I drove the car with that rear quite a bit and its still going. You will not break a 9" with a spool if its set up right in your car.
I like my fill plug, it makes it realy easy when you go to change the fluid. I also street mine every day with no problems. I got aluminum 3rd member, 35 gundrilled, exciter rings pressed on, drain/fill cap, 3.89 gears. Pm Matt TTP, he gave me a great price but it was on a gp.
This is what im looking at....
9" full spool
3.50 gear... not sure.. might go 3.70
35 spline axles
Was thinking the drain and fill plugs
now im not sure abot gundrilled axles.......
the star flanging i was told to stay away from because i will be driving thid car on the street..... i have no worrys about a spool on the street.. i dont care about eating street tires up.... ill be runnig two sets of rear tires... 15X8's with 275/60's and 28X10.50's ET Drags on 15X10's for the track.
Can you guys tell me more about what gundrilling axles and starflanging does for me? Im not woried about the strret because right after this goes in... ill be swaping out the 4l60e to a built th-350. Thanks
Kyle
9" full spool
35 spline axles
Kyle
Gun drilling/star flange loses about 8lbs an axle if I remember, its just a weight thing. The less anything that turns weighs, the less power it soaks up going down the track. I drove mine with no problems, wouldnt want to slide into a curb or anything
Drilling really doesnt weaken the axle much, just costs more money. If you are going with the stock 1st gear in the TH-350 I would go with a 3.70 over a 3.50, maybe even a 3.90 if highway driving wasnt a concern depending on what RPM you want to see going through the traps.
I will drive it on the highway some.......... in the summer.... only 8 miles each way... then cruising onthe weekend....... but will be trailored the 120 miles each way to the track.......I dont want to spinthe motor over 6600.... shift point... can i do that with a 3.90 rear gear??
Kyle
Kyle
9" full spool
35 spline axles
Kyle
9" full spool
35 spline axles
Kyle
Motorboater
i run a 9" with 4.71 gears and a spool. i drive the car all over when its out, and even in street trim with 17" nittos I don't notice the spool at all unless i'm making tight, slow turns, then it'll clunk.
i just fill mine through the breather hole that's on top of the drivers side axle housing, unscrew the fitting that's in there and squeeze in the fluid
Originally Posted by kp
depends on the converter/horsepower but 6600 should get you around ~128mph with your converter.
Can anyone break it down per gear and MPH??
3.90= 128mph
3.70=??
3.50=??
Thanks
Kyle
Shift points what you are looking for, all you have to worry about is making it through the traps at a certain rpm. An automatic car with a loose converter will slip ~4-600rpm. If you cant pull past 6600 I wouldnt use a 3.90. You will need 135+ mph to get in the 9s so if you dont want to swap gears go with a 3.70. I would try to get a 2.75 1st gear in the trans, that with a 3.70 is a pretty good combo - thats what I ran in the other car and 130mph was around 6200rpm in the 1/4.
I have a 4.10 in my car, 28" tires and I am crossing the traps ~71-7200 @ 133.5. So figure with 28.5" (tire growth) tires and 6500rpm get 134mph with a manual trans. So I am seeing ~650pm converter slip..
If you can pull more rpm out of your combo the larger gear will help out with the 60' but if you cant I would stick with a 3.50/3.70 and if you can afford the 2.75 1st in the trans it would be nice..
I would guess 135mph with a 3.70 and 143 with a 3.50 but it really depends on a lot on the converter plus tire growth. I would go with a 3.70, it may hurt you a bit when the power is lower but it will give you some room to go.
14 Second Truck Club
So what your saying KP is that a 6600rpm shift point and a 3.90 rear gear with a 28" tire is only good for 128mph...?? Will 128 be enough for 9's?? That is the end goal. 10's after the drivetrain goes in, and then lighten the car up, and more HP.
3.90= 128mph
3.70=??
3.50=??
Thanks
Kyle
3.90= 128mph
3.70=??
3.50=??
Thanks
Kyle
(MPH X Gear ratio)
------------------ X 336 = RPM
Tire Diameter
If you 3 out of the 4 you can get the last one. So 6600 rpm divided by 336, then times 28" tire and divided by 3.70 = 148 mph. The main thing to consider is this doesnt compensate for converter/clutch slippage or minor variances in tire height.
I just talked to Chris at APE and he said i should have no problem spinning the motor to 7000rpm..... so it looks like it will be a 3.90 gear. i am going to look into a 2.75 1st gear..... I used your convertor slipping as a Ref KP so if i spin the motor to 7K with tire growth to 28.3" and a 3.90 gear i should be able to do 137 MPH. Thanks for the input guys.. ill be ordering my 9" here real soon.
Kyle
Kyle
just have to watch your boost at 7000rpm and make sure you arent pulleyed up much, that 400rpm will be another 1 or 2 psi most likely. I am spinning this thing over 7500 so I dont thing yours going 7000 is going to hurt anything.
Downside of the 2.75 is its an extra 500.00 and a car with marginal traction may lose out with it but I think it will benefit you in the long run. I would like to have the 2.75 1st myself and will probably do it when I go through the trans soon..
Thanks
Kyle
I buy everything form TCI, most of the bigger vendors carry TCI stuff. I have a TH400 in this car, thats what came in it, my old car had a TH350 with the 2.75 1st. I wish I had a TH350 in here to be honest, my drivetrain is a horsepower sucking abyss but if I decide to spray 250 on it I need the beef
