Stock D/S with 12 bolt??
I've read a few posts but can't get a good answer.Im putting a Moser 12 bolt in my car and would like to know what I need to do to get teh stock aluminum D/S to work? U joint change, shortened or what? Ive heard both and Ive heard I cant use it at all..Please help, car is a 98 A4 WS6..
you'll need to stick it in place or measure your set up to dertermine if it's too short or too long. If it looks like it will work for you then you need to purchase a crossover u-joint to work with your stock ds and the 1350 yoke on the 12 bolt.
Originally Posted by HumpinSS
the stock DS will break with a few passes on some sticky tires. Save yourself the headache of making it work and buy a new CM/Mild steel one
These guys aren't kidding. I snapped mine in two pieces with the stock 10 bolt, BFG's and launching at 3K. The stock aluminum DS won't last you a night at the track with the abuse you'll be putting through with the 12 bolt.
Give Billingsley Racing a call, or visit the sight (to the right-->). They're custom length jobbers. There are many other companies that offer custom driveshafts as well. I net search should yield many.
