what shoud i do
what shoud i do
well guys after having my blackbird-ta for a month now i found out that i have wheel hop and the 315/35/17 wont stop spinning will my rear end hold up with nitto drag's on the rear and im taking care of the wheel hop with slp's LCA's need to know what to do
Yes, the SLP boxed lca's w/poly bushings should help the wheel hop. Sometimes Nitto's help create wheel hop. Play w/air pressure after lca install, also. You also might have to install lca re-location brackets, but I really doubt it....Also, you might consider a right side airlift bag run at 15-20 psi. Good luck---Stop the hop, or you'll be changing axles, or a rear.... WJ
