question on the stock rear....
is the rear end in the 93-97 the same as the one in the 98-02?
im thinking of buying one, my posi is going bad, and its from a 95 Z28
thanks for the info guys
todd
todd
14 Second Truck Club
The rears with traction control(4 channel) are different than the ones with just ABS(3 channel), also, I thought the later brakes on the LS1 cars were different also. Width, suspension, bolt pattern would all be the same.
Also, the internal components would be the same (gears, bearings, cases) as long as they are for the same ratio cases. 3.08-down or 3.23-up.
