373s
373s
Had 373s put in a couple of weeks ago and my car is still not shifting right.Ive had it to the shop that put them in and he worked on shift points,ls1 edit,much better but still not right.Should it be that hard to get right.Is there any spicific rpm or miles per hr it shoul be set at.Low throttle at about 35 it revs alittle before it shifts.At wide open throttle from a stop shouldnt I be having traction issues with KDWs on cold pavement?
Someone who's real sharp w/LS1 edit can straighten you right out...How much experience does your Edit man actually have? Should be popcorn for someone who knows what they're doing. 373's should shred street tires off the car, even w/stock converter, especially on cold asphalt, by mashing it from dead stop. WJ
