3.23's To 3.73's in 98 A4 TA - Any issues with ABS or Shift Points?
I know the speedo will neet be recalibrated - but what about ABS and shift points? Will any codes be thrown? Car is Non-TCS. If editing or adjustments are necessary - is it a simple LS1 edit change? How much $? Or would it be best just to pick up a cheap HPP3 and make the changes? Let me know what you can and thanks in advance... Patrick
