10 bolt on slicks?
Old 01-28-2005, 07:28 PM
carreras's Avatar
Default 10 bolt on slicks?
Is there anyway to modify a factory 10 bolt to run slicks without breaking it?
Old 01-28-2005, 07:38 PM
That's what she said...
TheBlurLS1's Avatar
need more info on the car, is it auto? 6speed? what kinda power to the wheels? transbrake?
Old 01-28-2005, 07:39 PM
Tranzor's Avatar
yep, add two more bolts.
Old 01-28-2005, 07:43 PM
carreras's Avatar
'98 SS 6speed around 330-340rwhp nitto drag radials
Old 01-28-2005, 10:37 PM
12stones's Avatar
slicks are drag radials are two different storys! you can still waste your 10 bolt with nittos, i know guys who've had it hold together, and others just rip it to hell. just depends how much of a shock you give it with your clutch. best to have a few extra $$ for a new 10 bolt though, or just get a 12bolt.
Old 01-28-2005, 11:07 PM
10 & 11 Second Club
Caveman's Avatar
I actually ran 11.0-11.2(382 allbore) about 250 runs and 11.6-11.8(heads+cam) with over 500 runs on the same 10 bolt, with a TA cover and 3.42 gears. I allways load the car up on the converter, seems to be more consistant ET and is much easier on the rearend than just hitting it off idle. With a 6 speed you are putting much more stress on the rear, a 10 bolt will deffinately break if you run 1.50-1.60 60'. Everyone I know with an M6 that dragraces alot and launches hard has broken a 10 bolt.
Old 01-29-2005, 07:26 AM
Mike98WS6's Avatar
Slicks+ M6+ 10 bolt=
Old 01-29-2005, 07:53 AM
9T7 Trans Am's Avatar
My friend's 10-bolt blew after about 20 5k clutch dumps. Nearly stock LT1 M6 with 315 Nittos.
Quick Reply: 10 bolt on slicks?
