buying a moser 12 bolt soon what else will i need
Old 01-30-2005, 09:08 PM
Nsty98LS1's Avatar
Default buying a moser 12 bolt soon what else will i need
just like the title says what all wil i need besides the rearend. i've also read a lot of complaints about noise so i'm going to check the setup before i install it. also i'm going with either 3.73's or 4.10's. how can i calibrate my speedo without a hypertech or LS-1 edit? also will i need to adjust my shift points(hoping not)?
Old 01-31-2005, 08:39 AM
7 Second Club
ty_ty13's Avatar
just installed my moser 12bolt with 4.10's speedo correction with HPT was a snap and didnt have to adjust shift points... factory should be fine... be ready to install new brake lines... i got the wildwood brakes with mine... i didnt buy the ASR or ABS....its just extra weight.... a conversion joint and yoke will be needed... unless you change drive shafts then you just need a yoke... i did the conversion for right now....if i hit 500rwhp ill change drive shafts.... thats all i can think of right now.... have fun!!
tyler
Old 01-31-2005, 12:07 PM
HASTINGSRJ's Avatar
Brake lines???? Not if you keep the stock breaks you dont have to change the brake lines. I had to zip tie mine up after insalling my Moser......
Old 01-31-2005, 01:06 PM
7 Second Club
ty_ty13's Avatar
right... i got the wildwood brakes with mine...
Old 01-31-2005, 03:49 PM
pewterta's Avatar
get some ear plugs...whine like hell
Old 01-31-2005, 09:48 PM
mitchotoole's Avatar
A lawyer for when they say they dont have any records of you ordering anything from them. But seriously, I ended up having to pay an extra 250 because the damn thing never worked and still doesnt work right.
