9" posi shot to hell
Old 02-03-2005, 06:13 PM
Tally TransAm's Avatar
Default 9" posi shot to hell
its official, the auburn pro limited slip in my 9" is shot to ****.
AFTER ROUGHLY 1500 MILES!!!!
damn im pissed
auburn said they can replace it for $135, where they charge me up front for like 450 (cost of a new one), mail it to me and refund me all but 135 back when they recieve my old one. also if the find something wrong manufacture wise with the old one ill also get the 135 back. they better find something wrong for it to let go this soon
it had like 5 passes on it, then it started to pegleg on the next trip to the track and has done it ever since. it only locks up like 1/10th of the time i hit it. auburn said there was a test i could do to see if it was working where you jack up one wheel with the tranny in neutral and see how much torque it takes to spin the one tire. a good one should be between 120-140 ftlbs, i can kick my tire and it fuggen free spins
im fuggen pissed
Old 02-03-2005, 06:59 PM
soslo's Avatar
wow - that sucks. What spline axles do you have?
Old 02-03-2005, 07:52 PM
14 Second Truck Club
mzoomora's Avatar
120-140 ft/lbs is ****. A good pro series should be 400+. The regular ones should be 200. The Eatons can be stepped up to 800.
Old 02-03-2005, 08:23 PM
1ScrudeDude's Avatar
How were you launching? What tires?
I feel for ya bro...
Old 02-03-2005, 09:02 PM
at the track i launch at like 5k with 28x9 et drags. only held up for like 6 passes though. 31 spline axles
Old 02-03-2005, 09:37 PM
Shoot, I just ordered some MT DR's, and only now I am figuring out that my Eaton posi is likely to get trashed. I got the "super strength posi," now I wonder if there really is such a thing.
And I DON'T want a spool.
I plan to do an experiment that might help this situation. I have a Two Step, which means I am at WOT as soon as the clutch is dumped. I have been blowing my Nittos off on just 2300-2500 rpm dumps, believe it or not.
Once I get my MT DR's (UPS LOST ONE TIRE, IDIOTS! ) I will try to launch...let's say around 3500 rpm (dump) and see if it either bogs or spins. Being that I am at WOT, I may not bog and get a good 60'. It's worth trying, maybe 2 weeks from now.
If I pull this off, many posi's could be saved because I believe it's the 5000-6500 clutch dumps that are killing the units. By setting the Two Step to a pre-determined rpm and dumping at WOT, I may just find that sweet spot so we are not loading 6 grand on the entire drivetrain.
Old 02-03-2005, 10:46 PM
xaon's Avatar
Auburn posis really aren't designed for drag racing. The cone style sucks for straight line. You should have gotten the TracLoc posi in your 9".
I recently fried the clutches in my posi in my Moser 9" after 2 years of ABUSE (6600rpm clutch dumps on slicks).
I didn't feel like going through the same thing again, so I put a spool in the car, it's a little annoying in parking lots, but otherwise fine My 2-step came in today so i'll be ready soon to make 6600rpm launches off the 2-step
Old 02-03-2005, 11:58 PM
BOWTIE's Avatar
damn im pissed
im fuggen pissed
Just out of curiosity, where you running any "additive"? If so, how much "additive" were you running.
Old 02-04-2005, 07:48 AM
im debating on getting a spool, but its still my daily driver. plus auburn is pretty much giving me another one
i was running the proper amount of additive, then it started happening and i changed the fluid and put in half of the normal amount of additive to see if it would stick better. no luck
Old 02-04-2005, 08:15 AM
Turo's Avatar
sorry to hear that, man. keep us updated on what auburn tells you, because this is the differential i was planning on going with.
Old 02-04-2005, 12:36 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
My posi 9" took a crap also after a dozen 5K clutch dumps. Spool or locker is the way to go.
Old 02-04-2005, 01:44 PM
koolrayz's Avatar
My auburn POS crapped out before I even made it to the track. I had a detroit locker in all last year. It is the way to go. I put 7,000 miles on the car last year and alot of passes It works like a champ and drives well on the street
Old 02-04-2005, 02:02 PM
how bad is the spool on the street with street tires????
do i have to worry about stress on the axles and bearings with it being a daily driver
Old 02-04-2005, 03:29 PM
Carlos, what tires were you running?
'Hard to believe that Moroso hooked hard enough for you to break anything.
On a related note, I just got off the phone with Strange. The tech guy told me they feel the Eaton SS posi is good until 500rwhp and 1.5 60's (with an M6.)
That may be be optimistic, and I wish they would write a guarantee on that...
Old 02-04-2005, 03:32 PM
!LS1 11 Second Club
1 track day at Bradenton (great track), plus 6 passes on a freshly VHT'd Moroso (was awesome)- between Pro Stock qualifying runs.
Old 02-04-2005, 03:57 PM
2MuchRiceMakesMeSick's Avatar
Go with a spool and never look back
Old 02-04-2005, 04:57 PM
Oh yeah, I did Bradenton in December, love that track That place hooks hard
You spoolin' on the street (or about to?) Were you still on the Nittos then?
Old 02-04-2005, 05:01 PM
!LS1 11 Second Club
BFG Drag Radials.
Went with another Posi, as my car will be seeing roadcourse track time in the near future. If roadcourse were not on the agenda, I'd a gotten a locker.
Old 02-04-2005, 06:51 PM
I need to ride in a spooled LS1 to check it out. At this rate, it may be my only choice. I want to run mid-11's with serious traction, maybe high 10's with a wet kit later this year.
Old 02-04-2005, 07:10 PM
timelord's Avatar
Locker!! I do 10K a year,spool too annoying in town for everyday.
