Tranny Swap
Old 11-14-2001, 05:37 AM
Sporks_Rule's Avatar
Default Tranny Swap
Ok this isn't your a4-m6 tranny or m6-a4 tranny question, but just out of wonder, when you swap out the stock m6 for an aftermarket m6, what has to be taken into consideration? I know the stock m6 is pretty strong, but it's a what if question so humor me <img src="images/icons/grin.gif" border="0">
Old 11-14-2001, 06:04 PM
c4c5specialist's Avatar
Default Re: Tranny Swap
Hi there,
The standard MM6 in any f car is rated at about 460 ft lbs, if my memory serves. As for aftermarket, syncros, inner and outer cones, and a few other components are changed.
I have MM6 transmissions taking 600 ft lbs, without any major work, so I would say it safe. If you change your fluids on a regular interval, you should be fine for some time to come.
Besttoyou, c4c5
Old 11-14-2001, 06:05 PM
BIGBOS's Avatar
I just want to know whos done an M-6 to A-4 swap and how much it costs...If I can't find someone to trade I would probably just to an FLP stage 4 tranny...
Old 11-15-2001, 03:49 PM
AJH LS1 Z28's Avatar
Actually, I would trade you if you were in Houston.. I have an auto with a built transmission. 3200vig, transgo and ALL Alto clutches.. I want a 6 speed soooo bad, I can taste it!! ...
Old 11-15-2001, 06:09 PM
ooblockxburneroo's Avatar
ajh ls1 ta i have a friend here in san antonio that is wanting to swap 6 speed for an auto i am going to give him your email to get a hold of you.
