? about Blowing a 10 Bolt...
Sometimes the axles break, sometimes the limited-slip carrier breaks, and sometimes the ring gear shaves off it's teeth like a crazy person eating corn-on-the-cob. The M6 cars with a good hooking set of rear tires and a high rpm launch, with a side-step of the clutch will do it with ease. It is a sickening feeling when you're sitting in the driver's seat and it happens....Many F body owners who have experienced it, awaken late at night, in a cold sweat, shaking uncontrollably... WJ
Originally Posted by Ferocity02
I am curious... I always hear about people blowing apart their 10 bolts at the races. I am wondering what exactly on the rear end breaks when this happens. If anyone has any pics that would be great. Thanks a lot!
I thought I was going to be cheap and put a circle track mini spool in my older camaro. I broke the pin once, and then I got a harder one that grenaded and tore a bunch of stuff up. But that was on a 9", I dont tell most people what happened, just "all that chevy power"
I've seen plenty of M6 rears go boom. When will my A4 put the 10 bolt out of it's misery? Last year a was cutting 1.7s on ET Streets, 3.23s, 3200 stall. This year I will have more cam, and 3.42s...
I sheared 6 teeth off of my richmond 4:10 ring gear. I got one run on the Et street radials- 11.73 with a 1.60 short. I even thought I was launching it easy! I had the moser axles as well as a pro auburn posi unit. I hear this common for this ratio though. It was worth it to run the above time
Originally Posted by pasbonsimon
Here ya go- see anything missing?
Originally Posted by WJ SOM SS
Looking at the condition of the cover and the carrier, I'd say that's a very high-mileage car...Am I correct? Carrier looks like gear oil was super-heated in the housing, or never changed.... Just my opinion from others I've seen. WJ
Had Strange 4.10s in my 10 bolt, with a T/A girdle and heavier gear oil (Redline 80w140)... launching at no more than 3k on Nittos, bolt on only car (337 rwhp) it lasted about a dozen passes or so before shearing 8 teeth off the ring gear.
this wasn't a "stock" 10 bolt...it had Richmond ProStreet 3.73 gears, a TA cover, and a Auborn Pro Posi.......it was as strong of a 10bolt as you could come up with.......the reason it lived as long as it did (about 50K miles with 400+ rwhp) was because I never had traction (no slicks and road race shocks/springs).....when I went to BFG drag radials is when I think it got hurt.....
it died all at once......I got up and didn't have really any noise as I drove to class in the morning.....that afternoon I couldn't hear the exhaust over the noise of the rearend......BOOOOOOMMMMMM
My buddy **** his out Saturady at the track. His 6th pass on his new MT drag radials. it sherred of 3 spider gears but apperas not to hurt the carrier too bad.
My friend just trashed his rear in his bone stock 96 Yukon, here are some pics of the carnage, I havent really seen anything like this happen before. Does any one else see something wrong with the carrier.
Last edited by 81LS1Camaro; 04-09-2005 at 05:01 PM. Reason: added the pics I forgot
