Any reason you couldnt machine an ABS ring to fit a spool?
Old 03-25-2005, 04:19 PM
GrannySShifting's Avatar
Default Any reason you couldnt machine an ABS ring to fit a spool?
Just take factory GM ring (or possibly the F150 ring INTIMID8 using) and machine it to sit between the ring gear and spool? Might have to machine a step into the spool flange but I dont see that being a HUGE deal
Old 03-25-2005, 05:50 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Or how about welding one on a diff. ?
Old 03-25-2005, 06:22 PM
chief455's Avatar
will the area the sensor in the housing is looking for be located EXACTLY as it should? That relationship is important to the ABS working correctly.
Old 03-25-2005, 06:25 PM
not talkign about one not functioning, just any reason Im not thinking of you couldnt get a reluctor wheels on a spool
Old 03-25-2005, 06:58 PM
chief455's Avatar
guess fitting up the exact spool you want to use will tell the story. Good luck - I have 3 ch and passed on 9" and spools due to this issue
