TA Girdle worth the $$$$$
Old 03-27-2005, 11:05 PM
1SLO6's Avatar
Default TA Girdle worth the $$$$$
TA cover with stud girdle worth the money or is it a waste of cash. Looking to maybe running my car about 2 times at the track on 26x11.5x15 MT slicks and stalling it about 3500 to 4000 rpm. Just want to know if it wll help in the sturdiness of the diff. I know what mostly breaks after a few good hits is the Gears thou.... Should i also runa synthetic gear fluid can anyone recommend one.....
Old 03-27-2005, 11:59 PM
WJ SOM SS's Avatar
Yes, a girdle cover and studbolt kit is money well spent to help out the 7.5" rear, especially if you're running the car at the track at all, IMO. WJ
Old 03-28-2005, 08:18 AM
LS1s R US's Avatar
Should be okay! And try some royal purple 75-140 for the fliud Qs.The M6s is the worst on get sets!
Old 03-28-2005, 08:41 AM
One Bad Z's Avatar
You need to decide what your goal is with the car. If you plan to make some serious horsepower then the ta girdle will be a waste of money and would be money better spent towards a 9" or 12 bolt rearend. If you dont plan to do too much to the car then getting the ta girdle would be a good idea.
Old 03-30-2005, 12:10 PM
1SLO6's Avatar
thanks for the info......
Old 03-31-2005, 10:34 PM
98sspullin'em's Avatar
what about a t/a cover for a 12 bolt?? is that needed??
Old 04-02-2005, 03:16 PM
6spdpewterZ's Avatar
I agree with SScotie. I plan on only running hig to mid 12's. I only have the 4.10's with the TA cover and it is holding the 6 grand launches on ET streets. i dont know for how long though
