Best 12 bolt rear end is?
That's a pretty vague question. You can have a 12 bolt built to run 8.00 if you want. If you are not going to run slicks, get an eaton posi and 30 splines for the 12 bolt. If you are running slicks, step up to the 33's. You can get a million options. You don't need many with only 500 hp. That will save you some cash.
Strange would be the better of the two.
With that much hp I would look into a Billingsley 9".
You should be alright with a 12 bolt but if your anything like me you wont stop at 500hp
