10 Bolt Sucks?
Ive Still Got The Stockrearend, I Have Replaced Axle. With The 6 Speed In These Cars The 3rd And 4th Gear Is Pretty Strong, If I Replaced The Gears With 4.10's Would I Lose Some Of The Top End Since I'm Gaining On The Bottom End?
Well Thursday at the track I took out my 6th set of gears 2nd carrier and 2nd stock tranny (3 weeks old). Its not going back together till my 12 bolt arrives and built tranny is done. This throwing money down the drain is done with this 10 bolt. This is my everyday driver, I am on vacation, they got a week to getter done.
Originally Posted by STEVE HERRING
YOU DIDNT GET THOSE NUMBERS FROM ONLY HEADS AND A CAM DID YA? WHAT KIND OF GAIN DID THE HEADS GET YOU?
don't think you'll be able to get away with an aftermarket carrier either, they break too. broke my eaton posi the week i installed it in 7 places on my first run at the track with it. only launched at 3k too, instead of my normal 6000 rpm.
ps. ls1's are EASY to make power out of. we just dynoed an ls1 corvette last week that made 549 rwhp and 566rwtq on a mustang dyno. add 13% for dynojet numbers. heads cam exhaust.
Originally Posted by SRP
.... ps. ls1's are EASY to make power out of. we just dynoed an ls1 corvette last week that made 549 rwhp and 566rwtq on a mustang dyno. add 13% for dynojet numbers. heads cam exhaust.
Even if you beef everything else up, the pinion support will always be a weak link. It allows the pinion to move slightly, which destroys the ring & pinion. There is a guy out there that gusseted the hell out of his 10bolt and he's had a few seasons on it running 10's. The bottom line is the 10 bolt isn't worth building unless you have some sort of 10bolt compulsion, etc.
Originally Posted by 1fstbird
i have never had a problem with my stock 10 bolt i run mickey thompson 26x11.5x16 et streets and the rearend is completly stock except for a set of 3:73 gears
wow........
countdown to exploding 10 bolt..........
u are braver than most
impressive
Never noticed caps- nice video, better license plate though!!!
thanx......
