M6 guys with surviving 12-bolts inside!
With all the threads I've read about M6 guys breaking 12-bolts, I thought it would be a good idea to see who hasn't broken one. I'm talking about 12-bolts with posi's in them. For those that have a 12-bolt that have taken a beating, speak up. What brand 12-bolt, what mods done, what tires are you running, what rpm are you launching at (dumping/slipping), and what gears are in the rear. Type of clutch would be nice also. I'm thinking this could help us guys who want to make our 12-bolt last.
I been running a Moser 12-bolt with 285/40-17 GS-D3's and I have the 33 spline axles with the heavy duty Eaton posi unit. No problems yet and I have tortured it some but not real hard as of yet. Not much gear noise so far either(3.73 gears). I think my 10-bolt would not have survived what the 12-bolt has already with the new tires. I like hitting the throttle in 1st at about 10 mph. Sets ya right back in the seat. My old tires on the 10-bolt would just light up. I do notice the inside tire hopping when I throttle it hard in a tight corner with the heavy duty posi unit. I believe they installed 800 lb. springs in the posi unit. I know that it grabs posi no matter what direction I am turning or how hard I throttle it. Quite fun actually
Just get a spool and you'll never have to worry about your rear EVER again.
And before everyone jumps on the "you can't daily drive a spool" band wagon. its not that bad and sometimes i forget i have a spool. and i don';t have power steering so its a little harder to turn in my car.
Mine is doing fine, for over 3 years now. I have 33 spline axles, 4.11's, and the Eaton HD posi. I never put friction modifier in it, so the rear end howls at me on tight turns But I'll be damned if it slips. If I'm touching the throttle at all around a turn, the inside tire skips It's survived what the 10 bolt hasn't, even though I've not gone very fast (7.4's in the 1/8th at 96 MPH, 3720lb. race weight). It doesn't seem to mind my 5500 RPM dumps on ET Streets with a SPEC 4 clutch.
Originally Posted by pewterta
12 bolts are fine for six speeds... im not gettiing the point of this thread....????
CMC
I broke my 12 bolt Mosor spider gears with 315/35/17 Nittio's with a 3,500 launch.
I don't thing the short side wall helped.
There has been a lot of broken 12 bolt spider gears with m6.
I'll be putting a spool it soon!
What scares me away from a spool is that it seems like it would be hard on the chassis.
Originally Posted by dug
So what you are saying is that if you dont mind driving around w/o powersteering you wont mind a spool?
your car will want to keep going straight when you turn the wheel but its only noticable at low speeds (like 20 and under). if you keep your power steering you'll probably never notice anything other than the slight ytire noise.
I was going to get HUGE axles too but then i read Moser web site.
Should you be concerned about breaking an axle?
To achieve maximum performance you should use the smallest axle available that will safely handle the torque your car produces.
The torque rating of Moser Engineering Custom Alloy Axles are as follows:
30 Spline - 6,200 ft. lbs. (per axle)
31 spline - 7,000 ft. lbs. (per axle)
33 spline - 8,200 ft. lbs. (per axle)
35 spline - 9,600 ft. lbs. (per axle)
40 spline - 12,000 ft. lbs. (per axle)
Which axle size is right for me?
The way to pick your axles is so one axle will handle all of the maximum torque your car can produce. That way it is practically impossible to break an axle because you have at least a 200% safety factor.
My Boyfriend broke his Posi twice, twisted the splines on 2 30 spline axles and most recently snapped an axle on drag radials of all things.
He launches around 6K on a QTP slick. Needless to say he's got a spool in there now. Funny to hear his car slowing down turning it sounds like eek,eek eek My 12 bolt is just fine, but it's only been on drag radials.
My 12 bolt is about 2 and half y/o. 33 Spline axles, 3.73's, Eaton Pro-posi, ABS, TCS and Girdle. I run Nitto DR's (315's) on the street and 27"x10.5" ET Streets at the track. I launch(dumping the clutch) around 4000-5000rpms at the track. My gears whine a lot and my pinion leaks. I have no complaints about my 12 bolt. Mods in sig.
