whats the fastes a 4 gen has run on the 10 bolt?
Old 04-08-2005, 04:54 PM
SDB
SDB's Avatar
Default whats the fastes a 4 gen has run on the 10 bolt?
I ran 10's last year and shooting for low 10's this year on a stock 3.23 gear 10 bolt...anyone ever go 9's on a 10 bolt (stock gears, axles, etc) in a full weight car? Just curious.
SDB
Old 04-08-2005, 06:18 PM
mikes02ls1's Avatar
SDB
I went 11.98@118.81 with 4.10 in my 10 bolt also all stock suspension..
Old 04-09-2005, 01:29 AM
PRAY HRD's Avatar
i've heard the owner of one shop has done some 9's, but i'm not sure how long it lived! not worth taking a chance imo. if you spit an axle at 100+ mph, it could be pretty ugly!
Old 04-09-2005, 06:35 AM
nikkev's Avatar
I do know that 3:23's are stronger gears than others and an auto takes it easy in the 10 bolt. I have driven probably 250 1/8 mile passes ranging from 8.9 to 8.0 with an average 60' time of 1.8-1.9 and my stock rear has NO metal shavings. I am hoping I can avoid having to buy a rear as I don't plan on ever running faster than 11 sec in my daily driver.
Old 04-09-2005, 07:56 AM
GM Muscle's Avatar
I've heard of a few low 10s on a 10 bolt. I believe they where around 10.3 but I'm not sure if they where stock. If your not planning on a new rear this season I'd put alittle money into the 10 bolt. For $500 you can do a good amount that will help it survive for awhile (or atleast give you a peice of mind). I'm replacing my axles, going with a stud kit & girdle, welding the tubes, and a few other small things. Hopefully, it'll hold up to some 10.50s.
Old 04-09-2005, 09:02 AM
cablebandit's Avatar
mine has plenty of 10 sec runs on it with a rear cover...3800# and 3.23...best so far is 10.34....looking for 9s soon when I go to 3.73 gears
