BIG PROBLEM from france
Hello, sorry for my english
my car is a pontiac firebird 94 v6 automatic
I wonder if you can identify this problem:
When i drive with my car and i arrive to a stop, the car drive very slowly and when i go again, a vibe arrives and goes to the rear axle, as the sprocket-wheel don't hook.
The ABS system lighted up.
I don't know if this problem is from the automitical transmission or the rear axle, differencials ?
The oil in transmission seems to have a good quantity and for the rear axle, i bought the oil in USA with additif GM.
Besides, the oil is the 95 140 but in the GM book, it's 80 95. Is there any problem ? But i will change it.
This problem is there after i drive for 30 minutes but it's doesn't do that.
I identify it with another solution, when i put on return and put quickly on drive.
All the more so since, the car drive normaly most of the time. If i arrive to a stop and i stop, the problem doesn't appear.
I count on you because in France, we are not very good for resolving this problem.
Before i destroy my car with my tools , i would prefer to have your help…
My english is limited. If you have some documents in order to resolve my problem (pictures, links,…), there are the welcome.
Thank you to everybody.
Is there a clunking sound when you decelerate and or accelerate?
If so I would look at the rear-end if there is too much clearance in those parts they will do as you described, but when the oil heats up the clearances reduce and so does your problem.
Maybee? just guessing.
P.S. **** France
P.S. **** France
Originally Posted by hawgs
I sent you a Private Message.
for information, i had poster the same mail one automatic transmission.
and the last answer is intresting. that do you thinks about this?
