help
So does mine. I had mine looked at and they said the Torsen posi units clunk a lot. Since then I have seen a lot of posts for clunking rear ends all over the net for 99-02 F-bodies. Seems to be considered normal.
You could also check the suspension too just to be sure the torque arm or other bolts aren't loose.
